4mill question regarding spacer plate
BLOODRAGE
Do your self a favor and ditch the plate and have domes cut for the stroker. You will need to have the porting done as well. Don't bother doing it with out port work, because it won't run near its potential and you will just end up taking it apart to do it later any way
So when u say porting,do you have to lower the transfers to match the stroke?
Awhile back I asked chucky at superior sleeve about getting the old stock stroke ss jug I had set up for a 4mil,he said it could be done but it wouldn't idle.pretty much told me what had to be done was to cut the transfers lower and use edelbrock epoxy to lower the top of the transfers and exhaust.am I makin any sence?lol
Tony at tdr pretty much said the same,only difference was he said it would be easyer with a degree wheel
