HJR 4MM cranks
Juss11
Kevin sells HotRods cranks, not rebuilt "Hotrods" cranks.  When I got mine from HJR last year it was shipped in the Original Box from hotrods.  Just specify that you want a hotrods crank because he also sells the cheaper cranks (as of last year).  Spend the extra money for a better quality crank.
Hot Rods gets my vote! Ask Kevin and im sure he will tell you what he sells...
&That is the exact reason I put up the cash for a Hot Rods crank....Build it right now so you dont have the failure and cost you even more to do the repairnbsp;
Garbage !!!!!!The abuse and hours that I've seen hot rods withstand is unimaginable- just pony up now for the hot rods you'll be glad you did "You can go broke saving money" couldn't be more true, most guys find themselves digging deeper to fix what could have been prevented the first time around Sent from my iPhone using Tapatalk 2
My vote is for a vitos 4mm long rod crank. Mine has been good so far. Only problem was keyway for water pump gear seemed to be off a little. Had to sand the key to make it fit the keyway. The rods are good tho.
I run a Vitos crank. No problems yet.
"YET"
