Oregon dunner Posted February 26, 2013 Report Share Posted February 26, 2013 Just curious on what people have there ride height set up at? I only ride the dunes and my suspension set up includes elka dune editions up front with lonestar +2 wider +1 forward. The rear is stock shock and a 6 inch swinger. I currently have mine setup 1" higher in the rear. Is there any gain in handaling if you go more in the rear then the front or vise versa? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 26, 2013 Report Share Posted February 26, 2013 This is right out of Elka shocks install book: RECOMMENDATIONS TO ADJUST THE RIDE HEIGHTWhatever ride height setting you choose, the height must be similar at the front and rear of thevehicle, with the front slightly higher (from 1/4 to 3/4 inch maximum). A higher ride height will provide more ground clearance with less chances to bottom out but will makethe suspension stiffer. A lower ride height will reduce the ground clearance and make the suspension softer, but will makethe vehicle more prone to bottoming out. Quote Link to comment Share on other sites More sharing options...
