Need help with Toggle switch
When I got my bike the previous owner had taken the key switch out and was just use inch the on/off headlight switch. I would like to eliminate the on/off light switch. I'm wondering if I can just replace the on/off with a simple on/off toggle switch. That way I can also locate the switch in a different area.. Any help/suggestions would be great.. Thanks
In order for the bike to run, the red/black wire must be connected to the black wire, and the black/white wire must NOT be connected to the black wire. Originally the red/black wire was connected to the key switch and the black/white wire was for the kill switch. Does that clear things up? Switch it any way you want.
I just have the two black/black white wires off the kill switch and I was thinking I would tie the switch into those wires.
