Yea the hole is there. I just tried the screw that I did have from the left carb on the right carb and it threaded right in. The funny thing is my bike idles fine now even with only the one screw being in there. Ever since I adjusted the one idle screw that I do have its been idling fine.
However I found an idle screw from vitos for $5.95 so i'm going to order that just to be safe. What problems could having only one idle screw cause? Could it cause a slight bog on takeoff?
It'll cause an air leak making your machine run lean. It would cause hesitation and high idle. It'll also make the shee run lean at wot which could cause a piston meltdown. You might want to get that screw....
