banshee#44 Posted February 22, 2013 Report Share Posted February 22, 2013 I have fox floats with comp. and rebound adjustments what are you guys running for air and the adjustments I weigh 200lbs so I'm looking to see who's running them at that weight Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted February 22, 2013 Report Share Posted February 22, 2013 What exact shocks and arm length? I'll get back too you tomorrow when im out in the shop ill check what i have mine at. Been since last year since i messed with mine. (Gen 2 Evols) Quote Link to comment Share on other sites More sharing options...
banshee#44 Posted February 22, 2013 Author Report Share Posted February 22, 2013 Stock banshee shock length on +2 +1 lsr a arms Quote Link to comment Share on other sites More sharing options...
banshee#44 Posted February 22, 2013 Author Report Share Posted February 22, 2013 And there the fox float x Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted February 23, 2013 Report Share Posted February 23, 2013 Here is my everyday settings I go with after test and tune for a while one day on a long whoops and jumps section back and forth back and forth trying shot loads of diff air and re/comp settings. Main chambers 52 Evol chambers 158 Hi comp 8 out Lo comp 6 out Rebound 3 out When you change air settings, make sure the tires are slightly off the ground. Quote Link to comment Share on other sites More sharing options...
