trpkkd Posted February 21, 2013 Report Share Posted February 21, 2013 I;m redoing my banshee and the shocks need to be cleaned and painted. I was wondering whats the easiest way to get them apart? Quote Link to comment Share on other sites More sharing options...
Nieskes Posted February 21, 2013 Report Share Posted February 21, 2013 What exactly are you trying to get apart? Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 21, 2013 Author Report Share Posted February 21, 2013 Trying to separate the coil spring from the shock asborber . Quote Link to comment Share on other sites More sharing options...
Burke Posted February 21, 2013 Report Share Posted February 21, 2013 stock shocks? Quote Link to comment Share on other sites More sharing options...
Finch Posted February 21, 2013 Report Share Posted February 21, 2013 what kinda shocks? this always works Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 21, 2013 Author Report Share Posted February 21, 2013 Yea stock shocks i just want to take the springs off. Quote Link to comment Share on other sites More sharing options...
t3h hott! Posted February 21, 2013 Report Share Posted February 21, 2013 if i'm not mistaken, front stock shocks are non serviceable. i think the rear is, but not the front. mattscss could tell you other wise thou. Quote Link to comment Share on other sites More sharing options...
Finch Posted February 21, 2013 Report Share Posted February 21, 2013 ya can get the springs off how else would people pc or chrome them? Quote Link to comment Share on other sites More sharing options...
bansheefromhell Posted February 21, 2013 Report Share Posted February 21, 2013 ya can get the springs off how else would people pc or chrome them? yeah mine are pc'd Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted February 21, 2013 Report Share Posted February 21, 2013 You need a spring compressor, and I BELIEVE once you have the tension off of the spring, the lower eyelet unthreads off the shaft. I don't know though, I have never messe with those pogo sticks. Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 21, 2013 Author Report Share Posted February 21, 2013 Okay thanks a lot I'll try that when I get to the garage today. Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 21, 2013 Author Report Share Posted February 21, 2013 Couldn't get them to break loose if they do unscrew have no idea how to get them apart. Quote Link to comment Share on other sites More sharing options...
Rustynail Posted February 22, 2013 Report Share Posted February 22, 2013 put them upside down in a vice the use ratchet straps to compress the spring down towards the workbench then remove the plate on top (really the bottom but its upside down) the releive pressure and slide the spring off. Thats how a 450 shock works anyways just figured stock was the same. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted February 22, 2013 Report Share Posted February 22, 2013 450 shocks use a C-shaped spring retainer. I'm not sure banshee shocks work that way. Once you have the shock in a spring compressor, you should be able to move it around and see what needs to come off. Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 22, 2013 Author Report Share Posted February 22, 2013 Yea the plates are solid on the banshee my sons blaster the plate is slotted and will slide right off with the spring compressed. Quote Link to comment Share on other sites More sharing options...
