trpkkd Posted February 19, 2013 Report Share Posted February 19, 2013 Are all the banshee swing arms the same through out the years? I have a 96 and was wondering if an 06 would work? Quote Link to comment Share on other sites More sharing options...
ginger Posted February 19, 2013 Report Share Posted February 19, 2013 They should be the same though the years. only major changes to the suspension was the j arm to a arm conversion. Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 19, 2013 Author Report Share Posted February 19, 2013 OK thanks that's what I thought just wanted to make sure. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted February 19, 2013 Report Share Posted February 19, 2013 Let's clear this up. Not all years of OEM swingarms are the same. 87-88 had the carrier mounted outside the swingarm ears with washers welded on the outside of the upper swingarm ears. 89 and newer had the carrier mounted inside the swingarm with washers welded to the inside of the upper swingarm ears. The inside dimension between the ears on the 87-88 is 4 3/4". Outside dimension to the outside of the washers is 5 1/2". If someone wants to post dimensions for a newer swingarm, that would be great. Also, 89 and newer had the rear ends of the rectangle tube flattened out. Don't know if that's necessary for sprocket and brake hub clearance. 1st pic is 87-88. 2nd pic is 89 and newer. Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 19, 2013 Author Report Share Posted February 19, 2013 So could I run an 04 swing arm on a 96? Quote Link to comment Share on other sites More sharing options...
Starwriter Posted February 19, 2013 Report Share Posted February 19, 2013 Yes, 89 and newer are all the same. Quote Link to comment Share on other sites More sharing options...
trpkkd Posted February 19, 2013 Author Report Share Posted February 19, 2013 Ok thanks Quote Link to comment Share on other sites More sharing options...
