RACxEMxWILLIE Posted February 19, 2013 Report Share Posted February 19, 2013 Ok, getting a big tax refund back and planning beefing up my 03 Banshee. Its completely stock except for the FMF fatty's. I was wondering what are the best mods (save porting/boring because im doing that). I was either gonna go with a new head or vforce reeds. Which one would be better for the dollar. And if it happens to be a aftermarket head, which one and what domes should I run? I really dont want to run race fuel, so anything under 20cc is out of the question. 1000 ft above sea level. Doing a new rebuild after winter. Thanks guys Quote Link to comment Share on other sites More sharing options...
erickson483 Posted February 19, 2013 Report Share Posted February 19, 2013 +4 timing is going to probably be the best (and cheapest) but you should upgrade your reed situation if they're stock. Pro design cool head is nice, but not necessary. I'd say 21cc domes if you get one though. If your riding style allows it, remove the air box lid or go to some pods. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted February 19, 2013 Report Share Posted February 19, 2013 Im at 600 ft on average and run 19cc on pump. Yes its ported but its mild. 157psi in each hole Quote Link to comment Share on other sites More sharing options...
spurdy Posted February 19, 2013 Report Share Posted February 19, 2013 Again? Quote Link to comment Share on other sites More sharing options...
RACxEMxWILLIE Posted February 19, 2013 Author Report Share Posted February 19, 2013 yeah it posted it twice for some reason Quote Link to comment Share on other sites More sharing options...
special06shee Posted February 19, 2013 Report Share Posted February 19, 2013 10mil cub/serval/dm/cheetah!! Your choice! But do a 10m Quote Link to comment Share on other sites More sharing options...
rubberneck Posted February 19, 2013 Report Share Posted February 19, 2013 4 stroke conversion Quote Link to comment Share on other sites More sharing options...
KINGpimp Posted February 19, 2013 Report Share Posted February 19, 2013 19cc on pump? Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted February 19, 2013 Report Share Posted February 19, 2013 vforce reeds and bump up the timing, maybe get tors eliminated to save the hassle when your jetting. i also like the lightned flywheel and some good tires. cant do much without traction.. i like the noss head and do yourself a favor and have your crank trued and welded if you plan on bumping the compression up. i would go with 19cc domes with the race gas but that depends on dome design, porting, and timming. you might want to talk to whoever is porting the cylinders to see what they recomend. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 19, 2013 Report Share Posted February 19, 2013 4mm stroker crank since you said you are porting it. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted February 20, 2013 Report Share Posted February 20, 2013 Yep.. 19cc on pump.. Remember that ompressin drops as the exh port is raised. 1 Quote Link to comment Share on other sites More sharing options...
mpd579 Posted February 20, 2013 Report Share Posted February 20, 2013 Boost bottle U should be able 2 find 1 cheap. Quote Link to comment Share on other sites More sharing options...
possum Posted February 20, 2013 Report Share Posted February 20, 2013 10mil cub/serval/dm/cheetah!! Your choice! But do a 10m this Quote Link to comment Share on other sites More sharing options...
