BeeCanBanshee Posted February 17, 2013 Report Share Posted February 17, 2013 Had my frame pc'd and want to male sure I have my ground contact areas clean anyone know off the top of there head? Does the coil ground through the mounting bracket? Only thing I have mounted so far. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 17, 2013 Report Share Posted February 17, 2013 I like bare metal on my coil mounting brackets. Other than that, you can essentially ground anywhere. Just make sure it's bare metal. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 17, 2013 Report Share Posted February 17, 2013 And bare metal to mount the voltage regulator.(I think anyway, can't hurt) Quote Link to comment Share on other sites More sharing options...
special06shee Posted February 17, 2013 Report Share Posted February 17, 2013 X2 bare metal on coil and regulator Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted February 17, 2013 Author Report Share Posted February 17, 2013 Ok thanks I don't run headlights so I don't have my regulator on. But thanks guys. Quote Link to comment Share on other sites More sharing options...
blowit Posted February 19, 2013 Report Share Posted February 19, 2013 Another warning, make GD SURE that your engine mounts ground properly to the chassis. Remember this, the ignition source coil and lighting coil reference ground from the engine. If the engine does not have continuity with the chassis, you can ground components till the cows start singing and it won't matter because that ground reference does not make it back to the engine. Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted February 20, 2013 Author Report Share Posted February 20, 2013 Ok so you mean make sure the front and back mounts are clean where they touch the frame? I don't have the dog bone looking mounts. And I am not running lights. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted February 20, 2013 Report Share Posted February 20, 2013 No ground is necessary in the ignition as long as all black wires are connected. Not sure about lighting. No sense in grinding pc off to mount the coil. I have zip-tied coils to the frame with no issues. Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted February 20, 2013 Author Report Share Posted February 20, 2013 Well I already sanded the coil mounting area but just enough for the coil to contact. I'm worried about the above said engine mounts need to be in good contact cause I think the sanded off powder there would be noticeable. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted February 21, 2013 Report Share Posted February 21, 2013 Don't worry about it. The black wire that runs out of your stator plug IS the ground. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 21, 2013 Report Share Posted February 21, 2013 Don't worry about it. The black wire that runs out of your stator plug IS the ground. I've heard varying opinions on this. Personally, I like to have several grounding points in case one fails. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted February 21, 2013 Report Share Posted February 21, 2013 I've heard varying opinions on this. Personally, I like to have several grounding points in case one fails. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted February 21, 2013 Report Share Posted February 21, 2013 It's not needed. It may be a coincidence that all my bikes are wired that way, or that I got that idea from Jason Menz who is one of the smartest drag racers in the sport. I know that they have grounds factory but unless you're running pvl (which sucks) you don't have to have them. If you do want to make a solid ground from the motor, just run a wire from the motor to th frame (as I have done on pvl equipped motors). Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 21, 2013 Report Share Posted February 21, 2013 I think I'll take my chances with a couple ground over no grounds. It's not like they're hard to install. Quote Link to comment Share on other sites More sharing options...
spurdy Posted February 22, 2013 Report Share Posted February 22, 2013 Do it once and do it right.....Lol! Quote Link to comment Share on other sites More sharing options...
