Reeds
Ak_grizzly
Power claims was the main reason. I was told at the time they were not worth switching from 3's-4's. the jump you were told you would see what not real and all hype. Keep in mind, one of these was a very well known builder. Now I suppose if you already have 3's you're doing something right so their isn't a need to pay for 4's.
^^^thats quite a different statement then what you said earlier.  You started off saying that a couple builders said they were "junk"...now you are saying they said "if you have 3's ,there's no need to switch".
  Anybody with half a brain knows the $$$ to power gain difference reed changes provide aren't worth it....unless you need reeds anyway.
VF4s are crap. Run boyesens
You clearly stated that Boyesens were better than V-4's. That's interesting because that would imply that the Boyesens are better than V-3's and V-4's since 4's out perform the 3's.  :yank:
Here Steven, here is an independant dyno curve for you to look at that shows the 4's making more power across the whole curve.
(You may not know how to read a dyno curve so I'll just tell you that in that 7400 to 8000 spot your seeing as much as a 7HP increase.)
Plus there is the whole 4 extra peak HP, as well as the better over rev. I'm not even sure if in this test they re-jetted the bike....because the motors all need one size larger pilot jet with the 4's due to the better airflow at low and mid RPMs.
So I don't know who the builders your talking to are....but I'll bet you none of them are selling Boyesens as their first choice of reeds these days.
Any time you can buy an extra 4-7 HP thru almost the entire RPM band that you engine is used in......and do it for just $200......DO IT!
02A11E36-3601-4117-8FE8-285991BE3826-290
I think who ever thinks what ever is junk should do a test with both. Stop cryin like a little bit*h. People have run them and obviously they keep selling both brands so they have to have there own reasoning. Different people like different power. Whether its a lot or just some more spunk.
I personally run 4s and there awesome imo, i know for a fact they are worth the money and are some damn good reeds. I have seen and heard proof of this in other instances also, but what do i know.
What other reeds did you compare them to?
Sent from my SGH-T679 using Tapatalk 2
