h20dies Posted February 15, 2013 Report Share Posted February 15, 2013 So my dumbass friend mixed my gas putting my tranny fluid TYPE F into my engine mixing it with my gas. I had no idea so I have been riding, Will this kill my engine? What should i do? How do i drain it? Quote Link to comment Share on other sites More sharing options...
oldskool Posted February 15, 2013 Report Share Posted February 15, 2013 Disconnect fuel line from carb,drain tank. Then drain carbs. Put fresh gas mixed with 2-cycle. You can do a compression test, but if you suffered damage its too late. I'd just see how it runs with new gas. 1 Quote Link to comment Share on other sites More sharing options...
Tech AS Posted February 16, 2013 Report Share Posted February 16, 2013 Im sure it wouldn't hurt to pop the head off and check to see how your cyclinder walls are looking and such. It takes two seconds. Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted February 16, 2013 Report Share Posted February 16, 2013 drain/psi test,then ride if its ok Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted February 16, 2013 Report Share Posted February 16, 2013 drain/psi test,then ride if its ok X2^ Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 16, 2013 Report Share Posted February 16, 2013 I'm sure it smoked like a mofo Quote Link to comment Share on other sites More sharing options...
h20dies Posted February 17, 2013 Author Report Share Posted February 17, 2013 That's what i would have thought but it was clearer then ever! No smoke at all Quote Link to comment Share on other sites More sharing options...
bansheefromhell Posted February 17, 2013 Report Share Posted February 17, 2013 is your friend a woman? couldn't see a guy doing that unless he was retarded lol Quote Link to comment Share on other sites More sharing options...
h20dies Posted February 18, 2013 Author Report Share Posted February 18, 2013 I would never let a woman mix my gas. He's pretty smart but he just messed up. Lolol Quote Link to comment Share on other sites More sharing options...
