Jereme6655 Posted February 17, 2013 Report Share Posted February 17, 2013 are you measuring the float adjustment with the carb gasket OUT like your supposed to? Also my bike used to leak when I would shut off the motor unless I turned the petcock off.......if this is the case for you....call up a site sponsor and get the carb rebuild kits from them.....the're about $15 per carb.....they come with EVERYTHING you need to refurbish the carbs. Did it to my carbs and it worked great. Quote Link to comment Share on other sites More sharing options...
Scooter350 Posted February 18, 2013 Author Report Share Posted February 18, 2013 I will definitely do that cuz i adjusted the floats again, seemed to have no leaks at the time but i went threw it and measured both seemed correct seats good but i would doubt that a rebuild thanks for the info. Quote Link to comment Share on other sites More sharing options...
Scooter350 Posted February 18, 2013 Author Report Share Posted February 18, 2013 * need a rebuild that is. Quote Link to comment Share on other sites More sharing options...
