rebelrock Posted February 13, 2013 Report Share Posted February 13, 2013 i have a tyson hillshooter chassis and i have noticed when shutting down after a pass the bike kinda feels like it wants to teeter totter side to side for a second. My alignment is dead straight! what will help this? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 13, 2013 Report Share Posted February 13, 2013 back or front? Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted February 13, 2013 Report Share Posted February 13, 2013 Stay in the gas. Never lift. Quote Link to comment Share on other sites More sharing options...
RobertR Posted February 13, 2013 Report Share Posted February 13, 2013 I feel ya there mine has a bad wobble during shut down. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted February 13, 2013 Report Share Posted February 13, 2013 where is your toe set at? had this happen on a stock cut chassis when i was running slight toe in.... adjusted it to dead straight (no toe in or toe out) and it corrected the issue... Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted February 13, 2013 Report Share Posted February 13, 2013 Most likely this is caused by: 1. Steering being toed "IN", on some chassis with bad tie rod geometry when the front sags under de-cel causing this issue. Even id it is "dead on sitting still it may change with even a little susp. travel. 2. The amount of caster is not enough in my opinion. Knowing brad personally id say to look at your alignment and tie rods, Brad has build a ton of chassis and this is not normally a problem on his stuff. If it were me, Id toe it out 1/8-3/16 and try it again. If it helps/fixes it , run it. If it doesn't look further into suspension geo. Chris Quote Link to comment Share on other sites More sharing options...
rebelrock Posted February 13, 2013 Author Report Share Posted February 13, 2013 My toe is dead straight! I may try to tow the out just a bit! Quote Link to comment Share on other sites More sharing options...
camatv Posted February 14, 2013 Report Share Posted February 14, 2013 some of those goofy ass 4 bar swingarms twist also. chassis should NEVER wobble or toss around at all... Quote Link to comment Share on other sites More sharing options...
sandbum80 Posted February 14, 2013 Report Share Posted February 14, 2013 I've had two hybrid chassis and rode more then I can count and can say not once have I had chassis wobble Quote Link to comment Share on other sites More sharing options...
rebelrock Posted February 14, 2013 Author Report Share Posted February 14, 2013 I run a single tube swingarm! I run 10x4 fronts! Too small mabey? Quote Link to comment Share on other sites More sharing options...
rebelrock Posted February 14, 2013 Author Report Share Posted February 14, 2013 Quote Link to comment Share on other sites More sharing options...
sandbum80 Posted February 15, 2013 Report Share Posted February 15, 2013 Did you buy it from directly from Tyson? Some reason doesn't look like his frame.. Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted February 15, 2013 Report Share Posted February 15, 2013 Is it just the angle, or are your bars really tweaked? That is quite the hood..... Quote Link to comment Share on other sites More sharing options...
joee20002 Posted February 15, 2013 Report Share Posted February 15, 2013 dont look like a tyson to me! Quote Link to comment Share on other sites More sharing options...
Stimbert Posted February 15, 2013 Report Share Posted February 15, 2013 DEFINATELY NOT A TYSON CHASSIS Quote Link to comment Share on other sites More sharing options...
