A arm to J arm conversion
JAGeSage
The RZR 800's have a arms all around. The 900xp has track and radius bars. TON! Sent from my iPhone using Tapatalk
Incorrect on both... sorry... lol
RZR 800's have neither a-arms, nor j-arms in the rear, and a modified upper spindle mount A-arm in the front. The rear is MUCH closer to a j-arm than an a-arm, though.
The XP's have trailing arms in the rear but use a modified 5-link to keep the trailing arms from snapping off at the frame pivot during an off-kilter landing. The frames on those things are pretty weak.
^^^Not doubting you at all but I was just at polaris looking at the 800s. I could have sworn there are a arms all around. On the 900's trailing arms not track arms. I totally fucked that up. On a side note and not to get off topic, but what do you know about the weak frames? Just curious, if you could pm me some info, because i was looking at buying another toy and was undecided between the 800 and 900.
TON!
Also, regarding the frames, it's not just RZR frames. It's pretty much all UTV frames. It's essentially just a square box under the cockpit, with everything else hanging off of it. If you don't have a very stout cage, consider it garbage. The cage is what gives this frame the majority of it's strength. It's like a unibody car, really.
