soccer4orlife Posted February 5, 2013 Report Share Posted February 5, 2013 I have a 89 banshee, tore down the motor at the end of season last year and built up a 421 serval. Put the bike back together, couldn't get a spark. Bought a new cdi, new ignition/coils, new stator, and another harness. Still no spark. I can't figure it out. Any suggestion will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 5, 2013 Report Share Posted February 5, 2013 Your on off switch is fucked, bad ground, Quote Link to comment Share on other sites More sharing options...
springer Posted February 5, 2013 Report Share Posted February 5, 2013 make sure the red/black wire is grounded. make sure the coil is grounded. Quote Link to comment Share on other sites More sharing options...
WaynokaBanshee Posted February 5, 2013 Report Share Posted February 5, 2013 Do you still have you're toes hooked up? If you do eliminate them and unplug them. Quote Link to comment Share on other sites More sharing options...
WaynokaBanshee Posted February 5, 2013 Report Share Posted February 5, 2013 Do you still have you're toes hooked up? If you do eliminate them and unplug them. tors not toes Quote Link to comment Share on other sites More sharing options...
soccer4orlife Posted February 5, 2013 Author Report Share Posted February 5, 2013 No tors, lol long gone. I will deft check those grounds again and that on/off switch. Thanks for the help guys. I'll keep ya posted. Cheers Quote Link to comment Share on other sites More sharing options...
tecate3matt Posted February 7, 2013 Report Share Posted February 7, 2013 X0303043 on the key for sure. I was looking around like a mad man when I couldn't get any spark with my banshee the other day. It was a wire under the little boot of the key tumbler, soldered it back on... came over on the first kick. Quote Link to comment Share on other sites More sharing options...
soccer4orlife Posted February 8, 2013 Author Report Share Posted February 8, 2013 Well I went through everything again, checked all grounds everything seems fine, just waiting on the new on/off/headlight switch. I also forgot to mention the on/off key switch was removed by previous owner and soldered together. Quote Link to comment Share on other sites More sharing options...
soccer4orlife Posted February 17, 2013 Author Report Share Posted February 17, 2013 Well guys I got exhausted replacing parts and tired of countless hours of trying to make what I had work. Took the motor out, threw it in spare frame, spliced the stator into the harness (different plugs), and boom! SPARK!!!!!!! So I guess my harness was bad and the spare harness was bad. Should have the shee up and running tomorrow. Again thanks to everyone for there advice. Cheers Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 17, 2013 Report Share Posted February 17, 2013 or you have a bad ground on the other frame. Quote Link to comment Share on other sites More sharing options...
