cesar392tx Posted February 5, 2013 Author Report Share Posted February 5, 2013 No I don't think it has it but I will put one tomorrow and its been a while science I did a compression test I will do one also tomorrow to see at what point it's at right now Quote Link to comment Share on other sites More sharing options...
HolySheet Posted February 5, 2013 Report Share Posted February 5, 2013 After you put that tube in, you should be all set. Quote Link to comment Share on other sites More sharing options...
cesar392tx Posted February 5, 2013 Author Report Share Posted February 5, 2013 Hopefully that will fix the problem I'm thinking on getting new carbs soon anyways any recommendations? Quote Link to comment Share on other sites More sharing options...
cesar392tx Posted February 6, 2013 Author Report Share Posted February 6, 2013 Does the choke work if not carb bowls are swapped ,zilla is rite compression is low might wanna get another test done and address the issue and watch who you have do the test not everyone does them correct no the choke doesn't work and i will but today i took for a spin and change my main jets and the clutch gave up on me lol so i need to get a new clutch Quote Link to comment Share on other sites More sharing options...
HolySheet Posted February 6, 2013 Report Share Posted February 6, 2013 Did the clutch go or did the adjuster screw in the center of the outer hub come out of adjustment? That has happened to me. Quote Link to comment Share on other sites More sharing options...
