Just put a Chariot 2pc stator cover on one of the bikes,this is the one with an outboard bearing support.
Also put on a Mattoon Water pump cover that i picked up @ Redline Racing (thanks Cam).
Everything except the pipes on this bike are machined or brushed aluminum and go well with the JDS Lockup support ring.
My impressions of the Chariot cover 1st:
1. Well packaged. (see unpacking photos)
My favorite tool for these bikes. Long battery life,suprisingly strong!! And small enough to fit in the tight spots
New sprocket nut that accepts the bearing support in cover
Finished product (matched well with all the other brushed aluminum i think)!
The Cascade Gear Slammer is nice too BTW
Now the Mattoon Water Pump cover.
1. This particular design is deep enough to clear the Chariot ultra High flow impeller BTW
The Mattoon cover is a good high quality part and fits well. The material feels much more "dense" than the Modquad i had. I dont know if Mattoon uses a higher grade Aluminum or its just thicker,but it feels MUCH higher quiality than the Modquad, plus itll clear the deepe Chariot water pump impeller as stated before.This one came from Mattoon polished,so i had to scotch brite the face of it to get it to match all the brushed aluminum. Plus i painted the flutes in it black to accent the black bike.
Also in the picture you'll see the JDS lockup cover reinforcment ring. What can i say,its another high quality,well fitting product,,,what more can you as for?
  All the vendors i mentioned here had great customer service ( Mattoon,Chariot,JDS,Redline Racing) and had more than fair pricing.
sweet!  you should scotch brite the chariot cover and get some of those machine marks out of them..  to me the "brushed alluminum" resembles more of a 50's cast look  i like it..
Sheeeit! Those machine marks are sexy! Kinda like pierced nipples on a hot girl. I mean normal nipples are cool, but nipples with a little bling........ Tasty.
