cbrian Posted December 27, 2013 Author Report Share Posted December 27, 2013 The company making the cradle kit is Fast from the Past (www.fastfromthepast.com) and it is only to mount a Yamaha RZ350 engine into the Aprilia RS250 chassis. The builder I selected was F.A.S.T. (www.farmandsandtoys.com) . I talked to several of them listed on this forum and I felt most comfortable with them and they had excellent communication. He echoed what was said previously, that staying with the 68mm bore and 4mm stroked crankshaft was the best to go with. The oversquare 72mm bore wasn't going to give me much more perceptible power and with vibration being such a concern, it wasn't worth it. Thanks to all of you that posted constructive comments for me to read, you are a great resource. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 27, 2013 Report Share Posted December 27, 2013 Keep us posted Quote Link to comment Share on other sites More sharing options...
Evans Ward Posted June 29, 2014 Report Share Posted June 29, 2014 I know this is an older thread but any updates? Quote Link to comment Share on other sites More sharing options...
cbrian Posted January 12, 2016 Author Report Share Posted January 12, 2016 It's been quite a journey with this bike, but the end is in sight. Just a little jetting and I'm off to the races. Thank you all for your posts, I get quite a lot out of them. This build can be seen on the Aprilia forum. http://www.apriliaforum.com/forums/showthread.php?303741-Gulf-Coast-Hybrid Quote Link to comment Share on other sites More sharing options...
NYUK Posted January 12, 2016 Report Share Posted January 12, 2016 nice work Quote Link to comment Share on other sites More sharing options...
Keno Posted January 12, 2016 Report Share Posted January 12, 2016 Just read the entire thread. Pretty cool, I'm loving the flask catch can Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 12, 2016 Report Share Posted January 12, 2016 I can't imagine riding one of these. The motors in these quads get crazy. I can barely ride that in a straight line. A small street bike must be a handful. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 13, 2016 Report Share Posted January 13, 2016 It's been quite a journey with this bike, but the end is in sight. Just a little jetting and I'm off to the races. Thank you all for your posts, I get quite a lot out of them. This build can be seen on the Aprilia forum. http://www.apriliaforum.com/forums/showthread.php?303741-Gulf-Coast-Hybrid Wow, that thing is Friggin' cool! Couple things you should look in to if you are gonna be winding that thing out longer then Dyno runs though. Check out the Pingel Dual outlet petcock and ditch that single nipple ASAP. And I would advise you look in to Billit bowls for the carbs. Plus there are a few nice ones with a baffle section that stabilizes the fuel around the Main jet. Ultra handy for running the twisty stuff wide open. Oh, when adjusting Floats. The easiest way is get it to sit flat and eye level while it is standing like it would in the bike. (Like in your string) watch the Needle and Seat action. Bend the tab so that it pushes that little spring loaded needle closes before the floats smash the carb body. Look at the float tube in the bowl, make sure it's not bent. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted January 13, 2016 Report Share Posted January 13, 2016 Awesome build and great write up! Quote Link to comment Share on other sites More sharing options...
cbrian Posted September 23, 2016 Author Report Share Posted September 23, 2016 It's totally finished now and tested. Banshee power makes it a real beast! http://www.apriliaforum.com/forums/showthread.php?303741-Gulf-Coast-Hybrid Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 23, 2016 Report Share Posted September 23, 2016 JEEZUS! That thing is pretty friggin' rad! Quote Link to comment Share on other sites More sharing options...
