Pwk issue
Pastrykiller
My 421 cub is a stock cast with 20cc domes on vp110 @ 32:1.
Elevation is 1000 ft
Issue 1.
Does it really matter if you use the brass idle screw versus the plastic. I think my slides are chromed but does it really matter?
Pilot jet is a 48
Main is a 158
Needle cel middle clip.
Air screw is 1.5 turns out
Issue 2:
Carb are synced with the tool and I am pulling a vacuum of 8 on both carbs. Shit just doesn't want to idle worth a shit.
Engine has no air leaks
Suggestions?
$30 seems steep for two screws....But getting a flathead in to adjust the right side is always a pain.  Anyone use these, are they big enough to use fingers?  When I busted the plastic screws I just went with the brass ones.  I just ordered a set anyway.
As for idle issue I'm not sure I can be much help.  ....but for some confirmation I'm running a 421 Serval and 35 PWKs.  Same jetting, 48 pilot, CEL needle, 158 main, and mine idles well.  I'm at <1000 feet.  I did have to crank in the idle screws till you could see the slides actually crack open a bit, then I adjusted them down from there while running.
When you say it idles bad, what does that mean?
I use the metal screws with my 35's. Easy to turn with your fingers and springs on them.
$10 I think they were for both.
http://www.farmandsandtoys.com/partdetail.asp?partid=119
I also use the taller tops and the lighter springs. I cut and stretched my stock springs before and they are ok, but the ones here pull a bit lighter.
Good luck.
