do-work-son Posted January 20, 2013 Report Share Posted January 20, 2013 What do you guys use when installing new stud in a cub block ? Heard vasoline or red locktight .. Quote Link to comment Share on other sites More sharing options...
Boston Posted January 20, 2013 Report Share Posted January 20, 2013 Just double nut one end and tighten them down. Don't use locktite Quote Link to comment Share on other sites More sharing options...
do-work-son Posted January 20, 2013 Author Report Share Posted January 20, 2013 They don't bottom out Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 20, 2013 Report Share Posted January 20, 2013 Post pic of stud Quote Link to comment Share on other sites More sharing options...
do-work-son Posted January 20, 2013 Author Report Share Posted January 20, 2013 This is the ones I used from cascade 8 short then 2 long... I screwed em in with some vasoline and torqued the head down to 20lbs last night just worried about it don't wanna have problem would rather tear it back apart now and do it right Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted January 20, 2013 Report Share Posted January 20, 2013 i made little threaded spacers up from a bolt and cut slots in them for a flat head screwdriver. gives the stud something to bottom out on. Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 21, 2013 Report Share Posted January 21, 2013 The stud in the upper pic needs to bottom in the hole to work like a stud. The lower one tightens til the bulge hits then worms like a stud. You should have all like the lower one pictured Quote Link to comment Share on other sites More sharing options...
