turbowrenchhead Posted January 18, 2013 Report Share Posted January 18, 2013 My elevation is 900 feet. I am running 20 cc domes. The jugs are stage 3 DIY port. I'm getting ready to buy the carb. I was thinking a 34- 36 pwk. What size pilot/mains should I start with? Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 18, 2013 Author Report Share Posted January 18, 2013 The intake is a custom setup off a sled that I bought from a board member. Quote Link to comment Share on other sites More sharing options...
Sandking Posted January 18, 2013 Report Share Posted January 18, 2013 Pilot 42 ish and main could be 165 to 205 depending on porting Quote Link to comment Share on other sites More sharing options...
mhoksch Posted January 18, 2013 Report Share Posted January 18, 2013 Don't do the 2-1. I learned the hard way, it SUCKS. You get way better performance from the dual carbs Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 18, 2013 Author Report Share Posted January 18, 2013 I have the stock carbs as well. I was going to try both setup's and keep the one I like and sell the one I don't. What would I shoot for pilot/mains on the stockers? Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 18, 2013 Author Report Share Posted January 18, 2013 I was leaning towards the 2-1 for better fuel economy and faster re jet if I need to on the trail. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 18, 2013 Author Report Share Posted January 18, 2013 Don't do the 2-1. I learned the hard way, it SUCKS. You get way better performance from the dual carbs Either people love them or hate them. I believe if you have a good intake that will make the difference on how well it performs. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 18, 2013 Author Report Share Posted January 18, 2013 Just did a compression test. I have 130 psi on both cylinders. Any higher and it might require higher octane. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 20, 2013 Report Share Posted January 20, 2013 If you are referring to the 440 manifold go ahead and run it. If it is a trinity or chariot you are fucked and will regret it. There really won't be much more fuel economy. The bike will just pull almost twice the fuel through he carb. I think if I were you a 38mm PJ or even a 39mm PWK would suffice. I have seen a few 2/1 and MOST are garbage. But there are a few trick set ups that do work. Also stick to the E series needles on them or you will get a weird midrange hesitation and sputter Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 20, 2013 Author Report Share Posted January 20, 2013 I don't remember what the intake is off of. The member I bought it off said they worked great. It has decent sized runners. I should look back in my history and contact him to ask. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 20, 2013 Author Report Share Posted January 20, 2013 If you are referring to the 440 manifold go ahead and run it. If it is a trinity or chariot you are fucked and will regret it. There really won't be much more fuel economy. The bike will just pull almost twice the fuel through he carb. I think if I were you a 38mm PJ or even a 39mm PWK would suffice. I have seen a few 2/1 and MOST are garbage. But there are a few trick set ups that do work. Also stick to the E series needles on them or you will get a weird midrange hesitation and sputter The 35 pwk fits in the boot real nice. Not sure if I can go any bigger before it won't fit the boot. Where would I get another boot to fit the larger carb? Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted January 20, 2013 Author Report Share Posted January 20, 2013 The intake is off a Yamaha 440 sled and modified to fit banshee. Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted January 20, 2013 Report Share Posted January 20, 2013 The 2-1 isn't bad I dunno how it compares to dual carbs since I don't have any. But I ran my banshee with a trinity 2-1 kit 33mm pwk, +4 timing, fatty's and it whooped 450s with exhaust and intake at the track. And still trail rode it. Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted January 20, 2013 Report Share Posted January 20, 2013 But I'm switching to dual carbs after rebuilding so I can see how it compares. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted January 21, 2013 Report Share Posted January 21, 2013 The intake is off a Yamaha 440 sled and modified to fit banshee. Run a 35PWK it'll be fine. We have a bike in our group making 65HP with one. (His is a Graydon though.) Quote Link to comment Share on other sites More sharing options...
