Finch Posted January 31, 2013 Report Posted January 31, 2013 More traction, less rotating mass Sent from my SGH-T999 using Tapatalk 2 Quote
trickedcarbine Posted February 1, 2013 Report Posted February 1, 2013 What is the advantage of narrowing up the rear end? Just to achieve the 'drag bike' look? The point is to put the weight in a more centered location. Think of it this way, if you stand with your feet spread as wide as possible you are distributing your weight out so that there is less pressure at each foot. If you stand with your feet together you are applying your weight to a more concentrated area. So when you see guys narrowing their rear ends up on quads and drag cars it is so that the weight is more focused or concentrated in one area which helps with hook up. 1 Quote
BANSHEEBEEFM2M Posted June 20, 2013 Report Posted June 20, 2013 Do i have to buy a blaster carrier to make this switch? Or will the blaster axle slide straight into a banshee carrier? anyone have a blaster axle for sale? Quote
Surfrjag Posted June 20, 2013 Report Posted June 20, 2013 It will fit in banshee carrier 03+ is direct swap the 02 and older needs the brake hub Quote
