1995 350 Banshee Posted January 15, 2013 Report Share Posted January 15, 2013 won't start with kick start but will start if you push it. Checked compression both cylinders are good. Changed plugs. But every so often it will kick start. Any ideas? Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted January 15, 2013 Report Share Posted January 15, 2013 Whats good compression? 125psi? Clean air filter and clean pilot jets For anyone to diagnose your issue it would be nice to know what has been done to the motor' pipes carbs jets airfilter. Sorry for the inconvenience in making you help us help you Quote Link to comment Share on other sites More sharing options...
special06shee Posted January 15, 2013 Report Share Posted January 15, 2013 Usually three things cause this more so then others.. Low compression,broken reed,blocked jet Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted January 15, 2013 Report Share Posted January 15, 2013 if it is winter time and the bike is jetted to run right at say 70* then it can also be your jetting as you will be lean making the bike hard to start. Quote Link to comment Share on other sites More sharing options...
1995 350 Banshee Posted January 15, 2013 Author Report Share Posted January 15, 2013 there 126 but yes pilot jet was plugged cleaned it and cleaned air filter. Would have anything to do to with plug wires or cdi box? Quote Link to comment Share on other sites More sharing options...
1995 350 Banshee Posted January 16, 2013 Author Report Share Posted January 16, 2013 keihen single carburetor, racing pipes Quote Link to comment Share on other sites More sharing options...
Nightmare Posted January 16, 2013 Report Share Posted January 16, 2013 keihen single carburetor, racing pipes racing pipes? Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
1995 350 Banshee Posted January 16, 2013 Author Report Share Posted January 16, 2013 Lrd pipes sorry bout that Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 16, 2013 Report Share Posted January 16, 2013 Same boat here, I got racing pipes and a hot port with a free flow filter. Special reeds too. The guy I bought it from said it has a jet kit. Any one know what my jetting is with the kit? How bout what it should be? I'm afraid to take the spark plugs out to see what they look like in case I can't get them back around my racing pypes 1 Quote Link to comment Share on other sites More sharing options...
1995 350 Banshee Posted January 16, 2013 Author Report Share Posted January 16, 2013 i just had to put a new rear bearing carrier on my banshee Quote Link to comment Share on other sites More sharing options...
1995 350 Banshee Posted January 16, 2013 Author Report Share Posted January 16, 2013 is yours not wanting to kick start either?? I have to push mine to get it start. Quote Link to comment Share on other sites More sharing options...
1995 350 Banshee Posted January 16, 2013 Author Report Share Posted January 16, 2013 i got k&n airfilter Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 16, 2013 Report Share Posted January 16, 2013 K&N just came out with a wicked mad sick K "X" N filter. It totally made my bike run harder now it dont not start without a tow... 1 Quote Link to comment Share on other sites More sharing options...
1995 350 Banshee Posted January 16, 2013 Author Report Share Posted January 16, 2013 wow thats kinda fucked up.. I Might try a might try a new filter as i just blowed this one out. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted January 16, 2013 Report Share Posted January 16, 2013 Maui waui mannnnnn Quote Link to comment Share on other sites More sharing options...
