Ronnie Posted January 4, 2013 Report Share Posted January 4, 2013 Hey guys. Ok so I moved and somebody threw away my bottle of oil. I kept it so I would know what to buy. Now im back to square 1. What oil goes in the crank case I know it has to be for a wet clutch system. I don't want to smoke my new clutch. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted January 5, 2013 Report Share Posted January 5, 2013 if you go to a parts store and ask for a wet clutch type transmission oil, you should be fine. i use motul transoil expert 10/40 Quote Link to comment Share on other sites More sharing options...
Rustynail Posted January 5, 2013 Report Share Posted January 5, 2013 I run ford type F transmission oil. Its cheap and widly available and never had a clutch problem Quote Link to comment Share on other sites More sharing options...
20Banshee03 Posted January 5, 2013 Report Share Posted January 5, 2013 I also run type F transmission fluid. After some research here on Bansheehq I found a lot of people run it. Quote Link to comment Share on other sites More sharing options...
Finch Posted January 5, 2013 Report Share Posted January 5, 2013 when ever ive used atf iv used the dex/merc one. Quote Link to comment Share on other sites More sharing options...
