Ctown208 Posted January 3, 2013 Report Share Posted January 3, 2013 I put some lowered and back 1 inch foot pegs on my quad and I'm having a hard time getting the oofs supported enough that their not pulling away from the flanges of the jugs.. Can you guys posted up some pics of your setups. It would be nice to see some other ideas other than my own.. Thanks in advance Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted January 3, 2013 Report Share Posted January 3, 2013 Mount the pipes to the cylinders with your springs, and support the pipes wher they want to sit naturally. Build your bracket to get to the pipes where they want to sit. What works for one guys pipes probably won't work for another's... Quote Link to comment Share on other sites More sharing options...
Ctown208 Posted January 3, 2013 Author Report Share Posted January 3, 2013 Yeah that's what I did but they are just to lose it seems like.. Seems like I want them to mount up tight against the flanges, but my support bracket isn't holding them solid enough, or I have weak springs. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted January 3, 2013 Report Share Posted January 3, 2013 sounds like you have some weak springs. if you don't have to struggle.....and I mean struggle......then your springs have lost their ability to hold your pipes tight. Replace em and try again....there should be no problem with them being held tight to your jugs. Quote Link to comment Share on other sites More sharing options...
Ctown208 Posted January 3, 2013 Author Report Share Posted January 3, 2013 sounds like you have some weak springs. if you don't have to struggle.....and I mean struggle......then your springs have lost their ability to hold your pipes tight. Replace em and try again....there should be no problem with them being held tight to your jugs. Yeah this is my next step, anyone know of some super strong springs Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 3, 2013 Report Share Posted January 3, 2013 Buy extra when you do and build a spare mount as they always seem to break at the wrong time. If your running same side pipes you need a pretty beefy mount. Also check mcmaster carr for rubber mounting studs. This will help take some stress out and hopefully will keep it together. I have personally given up on same side for a hillshooter do to mounts always breaking. Your sure the pipes are correct for the flanges as they make like 4 diff sizes? Quote Link to comment Share on other sites More sharing options...
Ctown208 Posted January 3, 2013 Author Report Share Posted January 3, 2013 Buy extra when you do and build a spare mount as they always seem to break at the wrong time. If your running same side pipes you need a pretty beefy mount. Also check mcmaster carr for rubber mounting studs. This will help take some stress out and hopefully will keep it together. I have personally given up on same side for a hillshooter do to mounts always breaking. Your sure the pipes are correct for the flanges as they make like 4 diff sizes? Yeah pipes are same side and are the correct setup flange size and pipe sz wise.. Any idea what that ruber mounting studs is called? Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 3, 2013 Report Share Posted January 3, 2013 Ill send you info tonight i printed out the page with all the sizes Quote Link to comment Share on other sites More sharing options...
Ctown208 Posted January 3, 2013 Author Report Share Posted January 3, 2013 Ill send you info tonight i printed out the page with all the sizesThanks I appreciate it Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 4, 2013 Report Share Posted January 4, 2013 Search for 9376k217. I use those in rubber between the peg and the mount. That way it dampens some of the vibration and hopefully the rubber shears before the mount breaks. 1 minute to replace and your back in action. I used 1/8 aluminum flat stock with the rubber insulator as the spacer. Just figure out what width you need and order that. Hope that helps. Remember to make spares while you doing it. Quote Link to comment Share on other sites More sharing options...
