BigRed350x Posted December 31, 2012 Report Share Posted December 31, 2012 There ya go loco... Engine yank / split competition at the next HQ meet. Teams of 2 or 3. Quote Link to comment Share on other sites More sharing options...
Tech AS Posted January 1, 2013 Author Report Share Posted January 1, 2013 I'm going with 5th,6th gear pinion in the tyranny worn out ,it gave you a noise while hot tell tale sign,the idler gear would shred in many cases but is worth a look b4 tearing into it,good luck The noise was from the water pump impeller rubbing against the case. There were friction marks and the impeller shaft was slightly bent. Im assuming that it bent after the gear broke or it bent causing the gear to break. But after all that was replaced no more noise. Just the tranny issue. Since that is most likely the case, any one got a cheap tranny in good condition laying around they might sell me for cheap? Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted January 1, 2013 Report Share Posted January 1, 2013 did you find the little pin that holds the water pump gear on the water pump shaft? may have fallen out and got ground up in the tranny gears... if not sounds like others have mentioned... probably welded a gear to the shaft.... Quote Link to comment Share on other sites More sharing options...
Tech AS Posted January 1, 2013 Author Report Share Posted January 1, 2013 Yeah i found that retainer pin. I actually had to reuse it lol. Quote Link to comment Share on other sites More sharing options...
