What carbs to run
thekevin
I recently bought the Banshee that is in my sig and wanted to get some opinions on carbs for it.  It is currently running stock carbs and I wanted to know if they were good enough or if I needed to start looking some larger ones.  I mostly just blast around on dirt roads and trails.
Stock domes and head now. Would the trinity 2 into 1 be of any benefit. I don't really plan on going larger with the motor, it is fine the way it is. Sent from my Galaxy Nexus using Tapatalk 2
NO, stay away from that junk ass intake. Stay with a two carb setup.
No one ever plans on going with a bigger motor, but they end up with one at some point in time. Do yourself a favor and save some money and stick with what you have now.
On down the road you can upgrade everything at once.
:whistling: That's what most of us say at first. Mark my words " Going bigger before the end of summer" Listen to the Boss. Start saving. You're going to need it. :banana:
Personnally I would change the Fuel Line set up at the T...You have it now so on a long WFO sprint it will flow through to the right carb and the left one will run lean...Make it so the lines are a little more equal in lenth and the T actually works as its supposed to.
