booxzzy Posted December 23, 2012 Report Share Posted December 23, 2012 sorry guys for this stupid question but how many pulses per revolution banshees ignition coil has? Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 23, 2012 Author Report Share Posted December 23, 2012 tnx mate,i set it up to 2 but i was told that its impossible to have over 12 000 rpms with fatty pipes Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted December 23, 2012 Report Share Posted December 23, 2012 i believe it is 2 but the tach feature isnt right on the vapor. at least with a banshee anyway. Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 23, 2012 Author Report Share Posted December 23, 2012 gotta get something accurate enough to check it Quote Link to comment Share on other sites More sharing options...
rubberneck Posted December 23, 2012 Report Share Posted December 23, 2012 vapor tach is useless on a shee (never tried it on anything else it could be worthless all the way around) The electrical system is simply too noisy on a shee, i tried everything could never get a consistent or accurate reading with the vapor Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 23, 2012 Author Report Share Posted December 23, 2012 Ill try to get readings directly from flywheel so i think that should be accurate Quote Link to comment Share on other sites More sharing options...
apeik Posted December 23, 2012 Report Share Posted December 23, 2012 let me know if that works booxzzy, ive had mine working great for a few years, but the tach does kinda jump around so i dont pay it much attention. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted December 23, 2012 Report Share Posted December 23, 2012 When I had my vapor I ignored the tach, but everything else worked great. I don't know how accurate the wheel speed sensor was either, but it would show 63-64mph on a stock geared, midly modded stock motor. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted December 23, 2012 Report Share Posted December 23, 2012 You can calibrate the speedo with a hand held tach and get semi accurate speed. Like phibert said though, the electrical system is too noisy for a accurate rpm reading no matter where you put the wire. Maybe if the tach wire was shielded... Quote Link to comment Share on other sites More sharing options...
beez33 Posted December 23, 2012 Report Share Posted December 23, 2012 I use a resistor plug and it seems like it reads pretty accurate. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted December 23, 2012 Report Share Posted December 23, 2012 So do I but according to the vapor I hit 11k with pro circuits on my old setup. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 23, 2012 Report Share Posted December 23, 2012 So do I but according to the vapor I hit 11k with pro circuits on my old setup. We've had Pro Circuits on a built 4 mill dyno at a peak RPM of 11,400. Don't get me wrong...it was in over rev and not making much for power at that RPM. LOL But they CAN rev that high. 12,000 on FMF's though.....No. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted December 23, 2012 Report Share Posted December 23, 2012 My vapor would show 12,500 with old school Don Elmer Gold Series FMF's... Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted December 23, 2012 Report Share Posted December 23, 2012 I could not get the tach to work correctly on the Vapor I had on my Banshee. I even took the whole bike to Trail Tech and had them work on it. I finally decided the tach was too hard to read/not needed on my bike and Trail Tech gave me a Vector to try( I got to keep the Vapor also). It works perfect and my speedo has been verifeid with a GPS. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 24, 2012 Report Share Posted December 24, 2012 DIGITRON! Done.... Quote Link to comment Share on other sites More sharing options...
