FASTOYS Posted December 21, 2012 Report Posted December 21, 2012 This is to compare our clutch kits vs. Tusk. We are not bashing the Tusk clutch kits we are just comparing them side by side to ours. A lot of people want the Tusk kits because they are cheap but hopefully from all this you can see why we don’t recommend them.Picture of the F.A.S.T. and Tusk frictions side by side. You can clearly see our frictions are thicker and stronger on the tabs that go into the basket. This is crucial for less basket wear and grooving because the load is spread evenly throughout each tab. Also added rigidity to the entire friction.Picture of our heavy springs vs. Tusk heavy springs. Notice how our springs are taller than the Tusk. When installing the Tusk springs the clutch bolts will thread almost a ¼ of the way in without even compressing the spring whereas on ours you have to “preload” the springs per say to start the clutch bolts. What this does essentially is give you more spring holding pressure.F.A.S.T. steel vs. Tusk steel. Notice the Tusk isn’t full like ours which give you less clutch apply area.F.A.S.T. vs. Tusk (friction thickness comparison) Longer clutch longevity!F.A.S.T. vs. Tusk (friction width comparison) More clutch holding area!F.A.S.T. vs. Tusk (tab width comparison) Our clutch fits tighter preventing less wear on the clutch basket from the tabs slamming back and forth when you dump the clutch. Allows for smoother clutch disengagement as well.F.A.S.T. vs. Tusk (tab thickness comparison) As stated above in the first picture, our frictions are thicker and stronger on the fingers that go into the basket. This is crucial for less basket wear and grooving because the load is spread evenly throughout each tab. Also adds rigidity to the entire friction. The #s speak for themselves!F.A.S.T. vs. Tusk (friction width comparison) More clutch holding area!F.A.S.T. vs. Tusk (side by side comparison) Quote
rjdgriff Posted December 21, 2012 Report Posted December 21, 2012 Nice post Jeff!!! So what is your price? On average how much longer do your clutches last? Quote
Finch Posted December 21, 2012 Report Posted December 21, 2012 im still running the oem fibers from 01 may be about time for a upgrade Quote
rjdgriff Posted December 22, 2012 Report Posted December 22, 2012 im still running the oem fibers from 01 may be about time for a upgrademy tusk clutch is about toasted, may be time for me to go FAST... And I know I need new cushions Quote
Nightmare Posted December 22, 2012 Report Posted December 22, 2012 I have a f.a.s.t clutch in the nephew's bike and no problems here. Quote
FASTOYS Posted December 22, 2012 Author Report Posted December 22, 2012 Thanks, Our F.A.S.T. CLUTCH is $99.95 http://www.farmandsandtoys.com/partdetail.asp?partid=34 I beleive the Tusk clutch is $50. Dont get me wrong , if you can only afford that much then it is what it is... We too can get cheap clutch kits but they have fibers just like the Tusk that flex a bunch when you twist them, and are very thin on contact area (tabs that go in clutch basket and cause wear). : ( If you want a cheapie clutch ask us for one, but we do not recommend or have them on our website, as we prefer to do it once and do it right ! Tedder (a well respected site member) has run many many many of our clutches as he likes to try different things in 1/4mi setup... He has told me many times that he likes ours the best out of all of the many he has tried. Quote
FASTOYS Posted December 22, 2012 Author Report Posted December 22, 2012 Nice post Jeff!!! So what is your price? On average how much longer do your clutches last? not sure how much longer than brand x but i know on high hp bikes we have had them last well over a season (year). My 10 mm Alky bike had our same clutch for like 4 years and countless runs. Quote
rjdgriff Posted December 22, 2012 Report Posted December 22, 2012 Nice post Jeff!!! So what is your price? On average how much longer do your clutches last? not sure how much longer than brand x but i know on high hp bikes we have had them last well over a season (year). My 10 mm Alky bike had our same clutch for like 4 years and countless runs. Right on... I'll have to give yours a try in the near future then Quote
Tedder Posted December 22, 2012 Report Posted December 22, 2012 Hey there Jeffrey! Been a while. Happy Holidays to you. Saw my name mentioned in your post and thought I'd add my nutswingin' .02 to the topic for the new guy's. We've (my family) bracket raced 1/4 mile asphalt Banshee's since 2005. Having done serious track testing over the years with a number of brands and compositions in our multi-stage lockups I can say that the Fast fibers and steels are excellent and all I'll run now. There are cheaper choices but you usually get what you pay for.... Link to an old youtube video someone posted of me. I'm at 4:52 http://www.youtube.com/watch?v=ebG3qMelLak Quote
vulvafan537240 Posted December 22, 2012 Report Posted December 22, 2012 i bought a FAST clutch a while ago for my buddy's bike and was impressed. still holding fine a couple of years later. Quote
camatv Posted December 22, 2012 Report Posted December 22, 2012 there is a reason you should pony up for oem parts when you can. the aftermarket is cheaper but there is always a reason for it. nice post! Quote
Rotax Raptor Posted December 22, 2012 Report Posted December 22, 2012 Ive ran just about all aftermarket clutches you can find and the FAST clutch has been the best so far. I ran the same FAST clutch in my 10 mil drag bike all this past seaon. A shit pot full of passes. Worth the money for sure. Quote
JayCLL Posted December 22, 2012 Report Posted December 22, 2012 I used a fast clutch in my 10 dm and it worked great Quote
springer Posted December 24, 2012 Report Posted December 24, 2012 i do happen to have a fast clutch in my bike now, without a lockup i might add, and am very satisfied. more than that, i am really impressed with this thread/write-up. i think more threads like this would be very beneficial, especially for the newer people. i would def encourage more threads on different topics. thanks jeff Quote
Wheelman Chassis Posted December 26, 2012 Report Posted December 26, 2012 I run ONLY fast clutch fibers in all my bikes. The clutch disengagement was the winner for me, no creap at all compared to other clutches with same fluid and setup. Quote
