Dyna rev box drl 300 cdi rev limiter
jdog
K so the rev box will work on a banshee? I have a 4mill 400cc shee and I want to be able to just hold it pinned wether it be racing or just ripping on the road and not have to worry about it over revving. Wat model can I use that will be best? I don't need launch control. Just more ov a limiter so I don't blow my crank again. If so can it be powered off the factory charging system. I will want to run it all the time. Thanks jeremy
Wouldn't a 2 step rev be more effective?
It takes a lot of work/tuning to get them to 60' & for consistency. It can also be your enemy with both.
Switch needs to be adjusted right, rpm settings, clutch set-up, carb set-up changes to name the main things. I probably forgot a couple.
 If your referring to the high side limiter, that can be used in certain racing situations also; like Index & Bracket.
