ric-ross1 Posted December 9, 2012 Report Share Posted December 9, 2012 like the tittle says i broke her in,was idleing on its own,still starts first kick, drove it with 25% throttle and it was running really good was going to adjust the throttle cable and as i was driving back it boged down, its like a bopbopbop sound, i tried adjusting the air screw but stil did it, carbs were dial in right sync wise before she started running. thanks guys Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted December 9, 2012 Report Share Posted December 9, 2012 Have the carb caps on the right carbs? Quote Link to comment Share on other sites More sharing options...
ric-ross1 Posted December 9, 2012 Author Report Share Posted December 9, 2012 i mean they both new from vito and the bike was running then it just started doing this, dont see how the carb caps would work then all of the sudden it dont. Just seems weird to me but i will check them. Quote Link to comment Share on other sites More sharing options...
okbeast Posted December 9, 2012 Report Share Posted December 9, 2012 Run out of gas? lol Quote Link to comment Share on other sites More sharing options...
ric-ross1 Posted December 9, 2012 Author Report Share Posted December 9, 2012 hahaha its all the way up still, filled up the thanks last night before i tried to started. Quote Link to comment Share on other sites More sharing options...
oldskool Posted December 10, 2012 Report Share Posted December 10, 2012 Did you turn chokes off, does it still fire on first kick? What about jetting Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 10, 2012 Report Share Posted December 10, 2012 Did you leave the tors or parking brake plugged in Quote Link to comment Share on other sites More sharing options...
ric-ross1 Posted December 10, 2012 Author Report Share Posted December 10, 2012 Did you turn chokes off, does it still fire on first kick? What about jetting if i pull choke is first kick or second if i kick it right never kicked before lol and they jetting was fine i mean it ran and everything smoked like a too stroke is supposed to. Did you leave the tors or parking brake plugged in this bike didnt come with tors when i got it and the parking brake aseembly doest have the bolt and the cable is cut. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 10, 2012 Report Share Posted December 10, 2012 Are the boxes still plugged in on the harness tho ? Quote Link to comment Share on other sites More sharing options...
ric-ross1 Posted December 10, 2012 Author Report Share Posted December 10, 2012 Are the boxes still plugged in on the harness tho ? what boxes?? I think i founf out whats wrong the main jet broke inside the nozzle and the top part was under the float with the washer looked like it was covering a hole on the bottom of the carb so i went ahead and ordered a new nozzle, new mains since the one that broke had a bigger hole then the left side. I hope thats what it is. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 10, 2012 Report Share Posted December 10, 2012 It's a little black box underneath the gas tank Quote Link to comment Share on other sites More sharing options...
ric-ross1 Posted December 10, 2012 Author Report Share Posted December 10, 2012 just went and looked at it and they were in. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 10, 2012 Report Share Posted December 10, 2012 Un plug those bitches. Quote Link to comment Share on other sites More sharing options...
ric-ross1 Posted December 10, 2012 Author Report Share Posted December 10, 2012 Are you talking about the ignition coil?? because thats all i have under the tank besides cables etc. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 10, 2012 Report Share Posted December 10, 2012 Are you talking about the ignition coil?? because thats all i have under the tank besides cables etc. No. Up towards the front to the left side(stator side) bolted up the same way as the coil. If its not there then don't worry. Seems like you found the problem anyway. Quote Link to comment Share on other sites More sharing options...
