booxzzy Posted December 7, 2012 Report Share Posted December 7, 2012 I have 372cc banshee with fatty pipes and power core 2 silencers,im running k&n air filter with lid,+4 degrees cdi box,280 main jets. With this set up (according to trail tech) at 20 degeees celsius i can get around 11 100 - 11 200 rpm and at 35 degrees around 10 700 - 10 800 (at sea level). If i shave head for 0.30 mm i suppose i would get over 12 000 rpm and im wondering is crank welding necessery? Quote Link to comment Share on other sites More sharing options...
lms1977 Posted December 7, 2012 Report Share Posted December 7, 2012 I doubt your going to see anywhere in those lines with a FMF pipe... but on your question.... Yes if your in there weld the crank... RPMS but also compression play a big role on unwelded cranks and seeing the OEM crank is known to seperate.... its a no brainer... weld it and be done. what he said Quote Link to comment Share on other sites More sharing options...
Nieskes Posted December 7, 2012 Report Share Posted December 7, 2012 Naaa just run er wfo! Quote Link to comment Share on other sites More sharing options...
Methfireroad Posted December 7, 2012 Report Share Posted December 7, 2012 U running a rotary engine Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 8, 2012 Report Share Posted December 8, 2012 The banshee ignition fires every 180deg, and both plugs fire at the same time. So if you are just hooked up to your coil signal wire with your trail tech, then divide your rpm number by two for real rpm. With fatty pipes that would also be a much more realistic number. 5, to 6500rpm is a LOT more realistic for your setup. -Jared Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 8, 2012 Author Report Share Posted December 8, 2012 The banshee ignition fires every 180deg, and both plugs fire at the same time. So if you are just hooked up to your coil signal wire with your trail tech, then divide your rpm number by two for real rpm. With fatty pipes that would also be a much more realistic number. 5, to 6500rpm is a LOT more realistic for your setup. -Jared i know that,when i bought shee it use to show 19999 rpms so i got the user manual for vapour from the internet and adjusted it properly,anyway ill film it and post it on youtube Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 8, 2012 Author Report Share Posted December 8, 2012 12,000RPM with fattys? You won't see that, even if you spun 12,000 you would be losing power at that point instead of gaining. The motor may sound like its revving high as hell but your probably dropping off on power i do actually,but up to 9000 maybe 9500 it pulls good Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 8, 2012 Author Report Share Posted December 8, 2012 No you don't i do lose power Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 8, 2012 Author Report Share Posted December 8, 2012 So you're saying you pull 12000+ RPMs? nah,i say i pull 10 800 Quote Link to comment Share on other sites More sharing options...
711jrp Posted December 8, 2012 Report Share Posted December 8, 2012 Don't be too harsh on the op, I have a vapour on mine and it tells fairy storys when it comes to rpms. the rest is all good though. Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 8, 2012 Author Report Share Posted December 8, 2012 Don't be too harsh on the op, I have a vapour on mine and it tells fairy storys when it comes to rpms. the rest is all good though. if vapour is wrong than im too,i was just reading the numbers Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 8, 2012 Author Report Share Posted December 8, 2012 how m i suppose to know the god damn thing is giving me wrong numbers,i set it up as it said in the instructions so i thought its accurate Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 8, 2012 Report Share Posted December 8, 2012 Those trailtech things are junk. Run a mychron or an alfano or something that is worth a hill of shit. You get what you pay for with electronics.. JMO Quote Link to comment Share on other sites More sharing options...
booxzzy Posted December 9, 2012 Author Report Share Posted December 9, 2012 Those trailtech things are junk. Run a mychron or an alfano or something that is worth a hill of shit. You get what you pay for with electronics.. JMO i gues u r rite Quote Link to comment Share on other sites More sharing options...
