With my mods, do I need race gas?
LanceG60
I have a cool head with 19cc domes, 2 to 1 pipe, air filter, boost bottle, stock carbs, who knows how its jetted...i bought it this way like a week ago and I'm getting all the bugs out of it. But I was talking to a atv mechanic and he said if I have 19cc domes I should be running nothing but race gas even if I mix it 50/50 or I'm gonna blow the thing up? True? He referred me to a shope that they compete with that actually sells race gas so it wasnt him just trying to sell something. What do you guys think?
I was running 18 cc domes and running premium pump gas and it ran fine it ran like that for 2 years wtihout a problem basicly the rule of thumb is anything over 160-165 psi for compression needs to be on some kind of race gas or mix anything under that is safe on pump gas i was running 165 psi ineach cylinder and i did not have a problem but i was pushing pupm gas to its limit find out what your comprression is and go from there.
it depends on your compression not on your altitude do a compression test and let me know what it is if it is under 160 then you are fine like i said i am running 18cc domes and i am at 400-500 ft. above sea level elevation does not make a difference its is you rcompression that determines what fuel to run. Race fuel will actually slow you down if your motor can not utilize it race fuel burns slower than pump gas.
Basically duece has it covered but I figure I'll throw in my experience.
I WAS running 93 and 18cc(which require race fuel at my elevation) domes b/c I didn't know too much about domes when I bought the shee and the dude ran race fuel in it.... Well long story short, one week after purchase my motor went KABOOM!!! I'm right around 800ft elevation and now I run 93 on 20cc domes.
Mike
I'm A little on the edge w/ 93octane and 20cc domes at my elevation. This is why I check the elevation on the place I'm going to ride at for a weekend trip. There is one place I ride and the elevation is 575ftabv. sealvl. and I've run 5tanks of 93 there :?:
BTW: Duece I sprayed some gizum on the bushings and smeared some grease on the seals like you said and the squeaking cleared up.
Mike
dragbanshee02 bad advice brother , duece is right with the altitude if you didn't know that you should listen and learn.
are you out to prove me wrong in every post that i post or respond to yes elevation will change your compression but as long as it is at or under 160 psi you do not need to run race fuel. and i suppose you would like to tell me that cast pistons are stronger than forged pistons and will outlast forged pistons like you said in the last post.
i dont recall saying anything about pistons, maybe chase did my point was elevation changes compression plane and simple and thats not my opinion but a fact and yes id agree if your under 160psi pump fuel is cool, as far as cast pistons over forged goes im uninformed in that area and would probally tend to just listen and learn in that thread.... and if you state things like elevation has nothing to do with compression in every one of your posts, then chances are someone will be out to "prove you wrong" have you ever thought that maybe you are wrong? every time you post if they are statements like "2+2=5" you can bet your ass someone on this forum will call you on it, and if either Chase or myself were out to pick on you, you would most certainly know it, ive yet to hear Chase piss in the wind on a thread most time his comments are right on check, i would tend to follow him on the piston tip.... so again sorry for the misunderstanding.......
Hey Duece,...I would like to find out how far above sea level I am. Can you direct a way to find out? I'm in Polk, Missouri. I'm the one that was short an Oring for my Coolhead a while back and dlnoss set me up with the part I needed. I got the coolhead on and ((((YEEEAH)))).....I have a permanent wind smeared grin on my face. HQ ROCKS!!
Klotzban1
(Banshees Rule)
  • 2 weeks later...
