Okiepred Posted December 4, 2012 Report Share Posted December 4, 2012 Finished build and no fire! Checked stator and bad took all electrical off wife's running bike and put on mine including wiring harness and still no fire! Tested her stator and pickup coil and tested good! Made sure all grounds are clean and shiny and still nothing! Any suggestions or thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 4, 2012 Report Share Posted December 4, 2012 CDI unless you included that already in the harness. I'm kind of in the same boat with my girlfriends bike. I'm gonna pull my stator and flywheel and throw on hers. if that doesn't work I'm gonna have to run through the harness. Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted December 4, 2012 Report Share Posted December 4, 2012 How is the pick up coil gap? Should be 0.015. Check the key switch and on/off switch? Quote Link to comment Share on other sites More sharing options...
Okiepred Posted December 4, 2012 Author Report Share Posted December 4, 2012 I have the gap set to 0.015 and I have the on/off switch off her running bike! Could it maybe be my flywheel? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 4, 2012 Report Share Posted December 4, 2012 I have the gap set to 0.015 and I have the on/off switch off her running bike! Could it maybe be my flywheel? does the flywheel rattle at all? but that will cause the bike to break up and sputter Quote Link to comment Share on other sites More sharing options...
Okiepred Posted December 4, 2012 Author Report Share Posted December 4, 2012 No the flywheel doesn't rattle it looks brand new to! The only thing I haven't took off of wife's running bike is the flywheel! I have tried about everything I can think of Quote Link to comment Share on other sites More sharing options...
Okiepred Posted December 4, 2012 Author Report Share Posted December 4, 2012 I have also checked continuity through my harness and all good! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 4, 2012 Report Share Posted December 4, 2012 hows the compression? Quote Link to comment Share on other sites More sharing options...
Okiepred Posted December 4, 2012 Author Report Share Posted December 4, 2012 Haven't done a compression check but seems to have good compression! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 4, 2012 Report Share Posted December 4, 2012 did you change the plugs? or check the plug gap? Quote Link to comment Share on other sites More sharing options...
Okiepred Posted December 4, 2012 Author Report Share Posted December 4, 2012 Brand new plugs and good gap! Getting spark now just every other kick it sparks? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 4, 2012 Report Share Posted December 4, 2012 how are the connections on the coil? I had a hard time a while back when the plug thing on the coil was loose and the only thing hollding it on was the rubber boot Quote Link to comment Share on other sites More sharing options...
Okiepred Posted December 4, 2012 Author Report Share Posted December 4, 2012 Mine are a little loose I will check that! Thanks Quote Link to comment Share on other sites More sharing options...
