Smart carb
crash&burn
If you notice in the picture the carb is not lined up nor is it pushed into the boot. When fully seated the brass fittings the vent lines attach to will be trying to occupy the same space. If they had a sleeker or shorter fitting for the inside vent lines it wouldn't be a problem.
Spoke with Corey just a little while ago, the issue is the large brass fittings are where the "tip valves" are to keep the carb from flooding when used on a dirt bike where it's laid over and flipped occasionally.
He's sending me the plain barbed fittings to replace them with so they will no longer stick out as far, the carbs they run on their banshee's do not have the tip valves so they hadn't run across this problem yet.
