Nightmare Posted July 19, 2013 Report Share Posted July 19, 2013 Is it in? Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted July 19, 2013 Report Share Posted July 19, 2013 I think it's in Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted July 19, 2013 Report Share Posted July 19, 2013 Looks like it will fit ...just real tight ? Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted July 19, 2013 Report Share Posted July 19, 2013 push harder son! Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted July 19, 2013 Report Share Posted July 19, 2013 FFS send them fuggers back. If they cant even send shit that fits the idea can't be much better. 102mm is the spread for all you listed. Guinea Pig is what you are. Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted July 19, 2013 Report Share Posted July 19, 2013 It'll take ages for them to be sent back to china. Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted July 19, 2013 Report Share Posted July 19, 2013 It's not a big deal to me, I'll either get it worked out or send them back for a refund. Quote Link to comment Share on other sites More sharing options...
VoOK Posted July 19, 2013 Report Share Posted July 19, 2013 I dont see the issue, just looks like the vent hoses are touching. Quote Link to comment Share on other sites More sharing options...
James_21 Posted July 19, 2013 Report Share Posted July 19, 2013 If its the hose like stated above, un-hook one and loop it through the other on then hook it back up. Looking at the pics that all it seems to be. Just my opinion Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted July 19, 2013 Report Share Posted July 19, 2013 If you notice in the picture the carb is not lined up nor is it pushed into the boot. When fully seated the brass fittings the vent lines attach to will be trying to occupy the same space. If they had a sleeker or shorter fitting for the inside vent lines it wouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted July 19, 2013 Report Share Posted July 19, 2013 Spoke with Corey just a little while ago, the issue is the large brass fittings are where the "tip valves" are to keep the carb from flooding when used on a dirt bike where it's laid over and flipped occasionally. He's sending me the plain barbed fittings to replace them with so they will no longer stick out as far, the carbs they run on their banshee's do not have the tip valves so they hadn't run across this problem yet. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted July 19, 2013 Report Share Posted July 19, 2013 So you are being the guinea pig with these carbs having the "tip valve"?? Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted July 19, 2013 Report Share Posted July 19, 2013 On the banshee I guess so, I don't mind. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 19, 2013 Report Share Posted July 19, 2013 Hmm, well what if this thing leans out your bike and it explodes? Or goes dumb rich and explodes? Or just all around explodes directly related to a carb issue? Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted July 19, 2013 Report Share Posted July 19, 2013 lol somehow I don't think anything will be "exploding." I pulled the check valve fittings and they fit just fine. Corey also sent a couple pics of the carbs fitted to their pikes peak 500 cheetah. 1 Quote Link to comment Share on other sites More sharing options...
