2000 Banshee for sale cheap
SOLD !!   2000 Banshee. I was going to part this out for the frame but I stopped myself. I think it’s to nice for that. I’ve owned it for about 7 years. No stripped threads, no mis-matched bolts.
THE GOOD: 20 mins. on a 65.5 bore and pistons from F.A.S.T
aftermarket chrome axle
billet clutch basket,newish clutches, plate and hub,shift shaft, Mull star, idler bushing, ez spring etc.
new Yamaha kicker
K-N filter,adapter,outerwear lid,no holes in box & TORS removed
Alba graphics and seat cover,decent uncut blue plastic
Aluminum push and grab bars
near new stock OEM tires and wheels
Toomey pipe clamps w/new rubber
Chrome handlebars
THE BAD: all the clutch parts to try to fix a “hit neutral problem” something internal, only in sand uphill under load
previous owner had bent the flywheel,broke very soon after new top-end, so left crank bearing is loose - have good flywheel and have had it running
bent left Jet-Hot coated Toomey pipe and silencer
NO title
THE UGLY: lower case has been welded from an apparent kicker gear malfunction,doesn’t leak and works fine
Just throwing this out there to see if any interest, 785-238-4252 in Junction City KS 66441 $800 the way it sits. (I could get it running in no time if interested)
