hotrodbanshee Posted November 25, 2012 Report Share Posted November 25, 2012 The ez pull clutch from fast racing or a asv clutch lever? Which one to use when running heavy duty clutch springs? Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted November 25, 2012 Report Share Posted November 25, 2012 I have had the EZ pull from fast and I am now going to the asv. I couldn't tell a big difference from stockto the EZ pull but I know a few ppl with asv and the are a hell of alot nicer Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted November 25, 2012 Report Share Posted November 25, 2012 Work out more. Get tanned and jacked. Quote Link to comment Share on other sites More sharing options...
Sandking Posted November 26, 2012 Report Share Posted November 26, 2012 X2 Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted November 26, 2012 Report Share Posted November 26, 2012 ASV without a doubt. had both. Very important to PROPERLY LUBE your cable.. Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted November 26, 2012 Report Share Posted November 26, 2012 ASV without a doubt. had both. Very important to PROPERLY LUBE your cable.. X2 on that... If u were you I'd just get a new cable while your at it Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted November 26, 2012 Report Share Posted November 26, 2012 i used to use that expensive cable lube , but switched to the Liquid Wrench brand cable and chain lube and like it better,plus you can get it at any auto parts store and the can is much bigger, get a lot more for your money. Quote Link to comment Share on other sites More sharing options...
Finch Posted November 26, 2012 Report Share Posted November 26, 2012 Work out more. Get tanned and jacked. x2 i still running the oem cable from 01 and the cheapest lever you could possibly get Quote Link to comment Share on other sites More sharing options...
5150banshee Posted November 26, 2012 Report Share Posted November 26, 2012 Seems need more GTL in ur life. Sent using Tapatalk Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted November 26, 2012 Report Share Posted November 26, 2012 ASV without a doubt. had both. Very important to PROPERLY LUBE your cable.. asv and new clutch cable thats lubed up good. i couldnt believe the difference from what i had before. my cable was soooo bad. Quote Link to comment Share on other sites More sharing options...
hotrodbanshee Posted November 26, 2012 Author Report Share Posted November 26, 2012 what model ASV lever should I get? Is there more than one model for it? Quote Link to comment Share on other sites More sharing options...
Z400Banshee Posted November 26, 2012 Report Share Posted November 26, 2012 I'm using a streamline hydraulic clutch on mine and love it. nice easy pulls and consistent Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted November 26, 2012 Report Share Posted November 26, 2012 Asv f3 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 26, 2012 Report Share Posted November 26, 2012 ASV F3 FTMFW! Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted November 26, 2012 Report Share Posted November 26, 2012 The longest one, so you have more leverage. Check out these straight from the draughtboard of kemo hump outta Chinatown... Quote Link to comment Share on other sites More sharing options...
