qtszx14 Posted November 24, 2012 Report Share Posted November 24, 2012 need someone close to alabama that can work on my banshee or give me info on how to set banshee up alky call mike 205/718/6518 Quote Link to comment Share on other sites More sharing options...
Finch Posted November 24, 2012 Report Share Posted November 24, 2012 good luck! Better get some new pistons on order start rich and dont get greedy. im gonna be knew to alky this spring hope it goes well Quote Link to comment Share on other sites More sharing options...
qtszx14 Posted November 25, 2012 Author Report Share Posted November 25, 2012 willing to drive 3-4 hours if need to let someone work on my bike i got it 4 years ago guy told me it was set up to run on alky or gas dont know much about the motor other than it has alot of port work with 41 mm carbs with power valves in them i need someone to look it over and tell what i have call me 205/718/6518 Quote Link to comment Share on other sites More sharing options...
Finch Posted November 25, 2012 Report Share Posted November 25, 2012 Post some pics up. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted November 25, 2012 Report Share Posted November 25, 2012 there has to be somebody around you that knows something about alky and 2 strokes. i dont though. Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted November 27, 2012 Report Share Posted November 27, 2012 there has to be somebody around you that knows something about alky and 2 strokes. i dont though. Lot's of, if not most of the guys here know something about alky and banshees. Probably more about alky than banshees. Quote Link to comment Share on other sites More sharing options...
qtszx14 Posted November 29, 2012 Author Report Share Posted November 29, 2012 This is the bike I need help with Quote Link to comment Share on other sites More sharing options...
qtszx14 Posted November 29, 2012 Author Report Share Posted November 29, 2012 Bike picture Quote Link to comment Share on other sites More sharing options...
Nieskes Posted November 29, 2012 Report Share Posted November 29, 2012 Ahhhh.........? Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted November 29, 2012 Report Share Posted November 29, 2012 I see notta Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted November 29, 2012 Report Share Posted November 29, 2012 what kinda carbs are they? what are the mains and dumps drilled to? if they are drilled at all... what pilot and what needle? gonna need a high flow petcock gut the gas cap and drill the vent hole in the cap as big as you can and still be able to hook the vent hose to it... do the carbs use a fuel pump or are they gravity fed? how far are you racing? gotta go one step colder on the plugs, gap them to .018 wheres your timing at? compression? answer these questions and we will move on... also start doing some reading on tuning alky.. take everything you know about tuning gas and forget it! completely different on alky.... Quote Link to comment Share on other sites More sharing options...
Ctown208 Posted November 29, 2012 Report Share Posted November 29, 2012 http://www.prosanddrags.com/forums/ubbthreads.php?ubb=showflat&Number=1557#Post1557 Someone shared this with me.. Quote Link to comment Share on other sites More sharing options...
