emtbanshee Posted November 21, 2012 Report Share Posted November 21, 2012 What is the best bearing setup for a 4 mil long rod crank. Tz and maxload or 2 maxloads ? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted November 21, 2012 Report Share Posted November 21, 2012 If you are running straight cut primary gears then the TZ and maxload setup is best. If you are still running the helical gears(stock type) then 2 maxloads is best. Quote Link to comment Share on other sites More sharing options...
do-work-son Posted November 26, 2012 Report Share Posted November 26, 2012 At what point should you yet considering upgrading the stock bearing and or gears? Quote Link to comment Share on other sites More sharing options...
Finch Posted November 26, 2012 Report Share Posted November 26, 2012 imo if ya have it apart do the bearings. straight cuts most will say there not needed untill you have alot more hp. Quote Link to comment Share on other sites More sharing options...
emtbanshee Posted November 26, 2012 Author Report Share Posted November 26, 2012 Just ordered maxloads from tdr. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
