Dual Output stator DC conversion
David DeLeon
Need to see if anyone has the link to properly wire a dual output stator. I have a 250 Watt stator with one lead putting out 150 Watts and the other putting out 100 watts. I have a one lead already wired into a rectifier and a battery. I would like to use the second output and also help with the output.
Can you simply wire a second rectifier? Or does something different need to be done?
When you search the forum the links that are on old qustions are no longer good.
Thanks
