low end bog 96 banshee
papasmurf96
Hey guys i have a 96 shee with pro circuit platinums and factory sound silencers, cylinders at .80 over stock, no porting yet, no air box jus k&n pods with prefilters, dynatek fs ignition, nology coil with hotwires and ngkbr8es plugs and a cool head with 21 cc domes. Running stock needle at clip 3, 310 mains and 27.5 pilots with air screw 1.5 out. Problem i am having is it will rev out clean from about half throttle to WFO but from idle to about quarter i have a bog. Any help would be appreciated. Thanks. Btw running 93 octane with yamalube 32:1, soon to be getting 19 cc domes and adancing timing with timing plate 2 degrees and running the dynatek on curve 3 and running vp c12.
plug was black and slightly wet after about an hours ride, pulled the 310's out put in the 300's and it cleaned thigs up quite a bit, at the same time i took out the carbon reeds and put the resin reeds back in and everything is right where it needs to be.
