Ball bearing vs arm style lockup advantage between
lms1977
What set-up are you running now? Do you think it's slipping?
I put it in the 1st post.. It's a 10mil serval running 22cc domes 7 deg timing shearer pipes 39mm pwk carbs my Cyl specs at 192-130 timings as cast it has been clean up.
I currently run a east coast Atv clutch with 3 Jd and 3 stock springs in his basket with my factory clutch hubs.. It works great no I don't think it slips at all I have pulled 4th gear up hills and launched in 3rd gear racing.
I'm just educating myself I want to build a bigger motor and wanted to see if there was a diff in the two lockups. I figure when I do the 535 I will probably put one in.
