MN Cold as Sh** Jetting
Tony M
Well here in minnesota its gonna be cold till next may... And well the shee is running odd. Now the warmest of days are gonna be no warmer than 50 degrees. I need alittle help picking out new jets.
Last weekend it started popping and hesitating in mid range, I took it out for a quick 5 min run once it was warmed up.
The banshee has the following done to it
High comp domes (150psi)
Open air box with filter
Toomy T6 high Rev pipes
Currently the main jet is 280 and i dont know what the pilot
Where is a good place to start here for 40 degree weather or so, 310? and do i change the pilot?
Ok guys you have helped me out so far but now that i have everything installed im having problems running.
I have 310 mains and 25 or 26 pilots and the needle is set on the 2nd up clip and the air to fuel mixture screw right now is 1 1/2 turns out
The banshee will run but eventually it will idle down and die and bliping the throttle will sometimes make it worse and it will die quicker. When driving it will do the same thing it will be going fine and then it will just seem like it runs out of gas. Next thing is that from idle to low mid range its really boggy and takes alitlle bit to get going/moving and sometimes it wont move at all unless you rev it up and then engage the clutch.
What should i do next
