sprinklerman Posted November 25, 2012 Report Share Posted November 25, 2012 it really sounds like they are setup for alky...but im not an expert on it. i ran it about 14-15 yr ago. and am going back to it next season. But from what you're describing,thats what you have. The PJets are for alky,also the pulse line. If the dump tubes are drilled for alky , then its going to be waaay rich for gas. What you have to do now,is take the carbs off and measure the dumptubes and see what jets and needles are in it. Get some numbered drill bits and see which one fits in the dumptube,thatll tell you the size. Quote Link to comment Share on other sites More sharing options...
bansheefromhell Posted November 26, 2012 Author Report Share Posted November 26, 2012 it really sounds like they are setup for alky...but im not an expert on it. i ran it about 14-15 yr ago. and am going back to it next season. But from what you're describing,thats what you have. The PJets are for alky,also the pulse line. If the dump tubes are drilled for alky , then its going to be waaay rich for gas. What you have to do now,is take the carbs off and measure the dumptubes and see what jets and needles are in it. Get some numbered drill bits and see which one fits in the dumptube,thatll tell you the size. il check it but it does run very well, starts easy and has never fouled a plug Quote Link to comment Share on other sites More sharing options...
