What pistons should i use?
Anthony133
Since i need to do a bottom end on my banshee, this is what ill be doing from stock: 7mil crank with 115mm long rods , 66mm (.080) bore and it'll be running on 100 octane gas. I want to run it as high compression as 100 octane will burn, but i need a piston for the 66mm, high compression and the long rod. What pistons do i use?? I saw that wiseco has pistons for all that but not all together, like they have 66mm pistons, long rod pistons, and high compression pistons but not one piston for all those uses. I heard bad things about namura but i dont know anything else.
What is your bore at right now? If your cylinders are say currently at .020 over then do not get them bored to .080 in the search for more power.......going larger in bores will not give you anymore noticeable power. do not waste your ability to bore your cylinders.
.080 is also the largest that you can safely bore......so.....one little mistake on jetting and your looking for new cylinders.
