rjdgriff Posted November 14, 2012 Report Share Posted November 14, 2012 Running a stock tranny? Quote Link to comment Share on other sites More sharing options...
SpeedRacer88 Posted November 14, 2012 Author Report Share Posted November 14, 2012 Nah end cut.... Sent from my Galaxy S3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted November 15, 2012 Report Share Posted November 15, 2012 (edited) IMO you need traction. You will be playing catch up if all you do is spin. How about find some rear tires that hook better, re gear so you can launch in 1st or 2nd and run like that? My bike is a play/trail bike that i drag race with on dirt/grass. It's geared/set up to hook. Took A LOT of testing. Like someone said, did the same thing over and over until i learned what it liked or didnt liked. Id recommend a n-down 1-5 over ride too. Regear it so you can used 1-5. You surely have the motor for it. In the end, set up > power. Edited November 15, 2012 by RagunCajun Quote Link to comment Share on other sites More sharing options...
SpeedRacer88 Posted December 3, 2012 Author Report Share Posted December 3, 2012 well she broke some more fibers, im lost my basket is smooth what else can cause it? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 4, 2012 Report Share Posted December 4, 2012 If your launching on pavement and its breaking fibers Id look at pulling some base pressure of of the clutch stack. If its getting good hook its probably chattering the thing o back its killing itself. Talk to a few pavement racers. I remember Wheelman had this issue at one point as well as a few others. If you have a lockup Id look to ditch some of them high pressure springs Quote Link to comment Share on other sites More sharing options...
SpeedRacer88 Posted December 4, 2012 Author Report Share Posted December 4, 2012 If your launching on pavement and its breaking fibers Id look at pulling some base pressure of of the clutch stack. If its getting good hook its probably chattering the thing o back its killing itself. Talk to a few pavement racers. I remember Wheelman had this issue at one point as well as a few others. If you have a lockup Id look to ditch some of them high pressure springs i have a sling shot and stock springs. it doesnt really get good hook i have dirt tires. i just road race every now and then. i don't understand y they are breaking. the clutch basket is super smooth no grooves. Quote Link to comment Share on other sites More sharing options...
SlowerThanYou Posted December 5, 2012 Report Share Posted December 5, 2012 i have a sling shot and stock springs. it doesnt really get good hook i have dirt tires. i just road race every now and then. i don't understand y they are breaking. the clutch basket is super smooth no grooves. Plain & simple your clutch set-up is not happy; it's clutch chatter & that has already been brought up. How do you fix it. Some times it take less base pressure/sometimes more. It could be in your dynamic weight application also. You may need to slow up or quicken your slingshot application. There are some other tricks that can be done depending on where it's occurring in the clutch pack. Wheelman had a neat little machining trick/tip. There's no set answer for your problem other than you need to make changes till it's happy. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 6, 2012 Report Share Posted December 6, 2012 Plus you filed your grooved basket till it was smooth again. Sounds like a good fix....but if you didn't take the exact amount of material off all the basket fingers....then you could have just a few of them that are making contact with the fibers before the others do. This can shock sections of the fibers and even cause them to flex and bind. This can also cause them to break. You can't cut corners with the clutch.....unless you like pulling clutch covers often. Quote Link to comment Share on other sites More sharing options...
SpeedRacer88 Posted December 18, 2012 Author Report Share Posted December 18, 2012 good call windy... new basket all good now Quote Link to comment Share on other sites More sharing options...
