g-force Posted October 27, 2012 Report Share Posted October 27, 2012 I just switched from a stock stroke dune port motor with stock carbs to a hjr 4mill with 35pwk a/s. Kevin recommended 158 main, 50 pilot, cel needle on middle clip. The main was close I'm at a 155 now, but the pilot and needle seemed rich, I,m down to a 42 pilot and the needle lowered to the last clip which helped alot but I think I may need a different needle, because still to rich, Which needle would be slightly leaner than the cel? HJR 4 mill shearer pipes 35 pwk a/s chariot intake kn pods 50:1 1000'elevation Quote Link to comment Share on other sites More sharing options...
Bkm2006 Posted October 27, 2012 Report Share Posted October 27, 2012 im running a stock stroke dune ported motor from f.a.s.t im at 900ft. i have same carbs 35 pwk a/s im running 158main 42 pilot and needle in middle clip. bikes a bit rich on the main but bike rips and revs out smooth. not sure on my needle jeff sent it with the jets if im not mistaken i think its a cel. why are you runnning 50-1? id run 32-1 or 40-1. make sure your carbs are synced well seems like your close on the jetting. do a plug chop. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 28, 2012 Report Share Posted October 28, 2012 Those Air Stryker carbs seem to have a much different (stronger) signal then the regular PWK. They typically jet out a few sizes smaller then the regular PWK will. So definitely don't be to worried if you find your self around a 148 after it is all said and done. BKM, that sounds a little rich for strykers on a stock stroke. You sure that yours aren't regular PWK's? Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted October 28, 2012 Report Share Posted October 28, 2012 32:1 is the way to go Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted October 28, 2012 Report Share Posted October 28, 2012 32:1 is the way to go SAYS WHO? Quote Link to comment Share on other sites More sharing options...
g-force Posted October 28, 2012 Author Report Share Posted October 28, 2012 I,ve always ran 50:1 with no issues. I put in a 152 main and will do a plug chop, I,m thinking maybe I was to rich on the main and the needle was ok? I had very little exhaust smoke with my stock carbs, and now it's smoking alot. So you think I could end up at a 148 main? Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Bkm2006 Posted October 28, 2012 Report Share Posted October 28, 2012 Those Air Stryker carbs seem to have a much different (stronger) signal then the regular PWK. They typically jet out a few sizes smaller then the regular PWK will. So definitely don't be to worried if you find your self around a 148 after it is all said and done. BKM, that sounds a little rich for strykers on a stock stroke. You sure that yours aren't regular PWK's? yep im deff running a/s ...im deff rich but no way am i pig rich, 155 main i think would be almost dead nuts for me. Quote Link to comment Share on other sites More sharing options...
g-force Posted November 10, 2012 Author Report Share Posted November 10, 2012 Can anyone recomend a different needle, still too rich. Thanks. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted November 10, 2012 Report Share Posted November 10, 2012 I am also having the same problem and I have the same mods and exact setup as g-force. The problem is when in gear in a lower rpm and speed and from basically no throttle to wot it bogs out. At higher rpm and speed its fine. I put the needle clip on the bottom and it seemed to help some what. I'll try to make a video on the go pro tomorrow so you can hear it guys Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted November 11, 2012 Report Share Posted November 11, 2012 heres a video of whats going on. thoughts everyone! Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted November 12, 2012 Report Share Posted November 12, 2012 SAYS WHO? Your mommy Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted November 13, 2012 Report Share Posted November 13, 2012 42 pilot 155 main cel needle bottom clip improved it some what from middle clip. gonna try bumping up the pilot to 45 and start over on the needle Quote Link to comment Share on other sites More sharing options...
