jbooker82 Posted November 8, 2012 Report Share Posted November 8, 2012 The part I don't like about a arms that use hiem joints on the upper arm where it mounts to the frame is setting the Caster. You don't just thread the joints all the way in and call it good. You have to use an angle finder to set the correct angle between the top and bottom ball / hiem joint. If you don't the steering won't feel right. It will ethire be hard to turn or unstable at high speeds. Quote Link to comment Share on other sites More sharing options...
